Connect the amps to a power cord (that only you know about) with a inline fuse of about 1 or 2 amps. When some drunk fool cranks it to 11, pop goes the fuse not your speakers and amp. Then look at the drunk fools face.What can I do to be sure that rented amps and speakers can't be damaged by idiots?
I realize that someone will reeducate the idiot, but give me some guidelines to over modulation at the input.
Yugh confrontation is not an option. I tend to stay away from people.Connect the amps to a power cord (that only you know about) with a inline fuse of about 1 or 2 amps. When some drunk fool cranks it to 11, pop goes the fuse not your speakers and amp. Then look at the drunk fools face.
Then ask "nicely" for the drunk fool to pay $100 for a new amp. (secret fuse)Yugh confrontation is not an option. I tend to stay away from people.
That sounds good. ..... I cant see anyone doing it though.Then ask "nicely" for the drunk fool to pay $100 for a new amp. (secret fuse)
That might work with the people that I am dealing withIncandescent lamps are sometimes connected in series with drive units, particularly tweeters and midrange units. High currents cause the filament to heat up and its resistance to increase rapidly, thereby, reducing the power to the loudspeaker. It may seem a little crude but it can work very effectively as the filament is subject to the same heating affects as the loudspeaker coil and it's the heat that does the damage.
Have a look at the link I just added above....I can tell them that they are LED's.
I agree but if you do it loudly in the silence of no music or audio the next fool won't touch the amp and will turn their attention to something else to break like maybe their neck.That sounds good. ..... I cant see anyone doing it though.
I did that, successfully. I took out the 3 amp speaker fuses and installed 1 amp fuses. The idiot cranked the amp up, exactly as I told him not to do and the fuses blew.Connect the amps to a power cord (that only you know about) with a inline fuse of about 1 or 2 amps.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
