Unbalanced Three Phase : How to calculate total power ?
kbarb
Joined Dec 29, 2008
6
In our building, we have a four wire 208v/120v Wye service.
I'm trying to measure the watts used by a subpanel, but the loads are unbalanced.
For example, for the 208v lines (black, red, blue) I get :
-- 42A
-- 84A
-- 80A
I know about P = √3 Vl × Il × cos φ where cos φ = power factor, but that's for balanced scenarios, right ?
I'm going to have to guess at the power factor - most of the loads are lighting & computers/monitors.
But anyone know how to calculate the total power draw ?
If you look on this page, Three Phase Current - Simple Calculation and look at the "Balanced Voltages" section it implies that for unbalanced systems you can still calc as such :
  • the line to neutral (phase) voltage VLN = 208/√3 = 120 V
  • phase 1 apparent power = 42 x 120 = 5040 VA = 5.04 kVA
  • phase 2 apparent power = 84 x 120 = 10080 VA = 10.08 kVA
  • phase 3 apparent power = 80 x 120 = 9600 VA = 9.6 kVA
  • Total three phase power = 5.04 + 10.08 + 9.6 = 24.72 kVA
Anyone know if this is correct ?
WBahn
Joined Mar 31, 2012
30,078
Yes, that looks correct.
As you say, you would have to guess at the power factor and that could have a significant effect on your real power.
As a quick sanity check, you can take the average of the three currents (which would be 68.7 A) and throw that at the balanced three-phase formula and see if you get something that is in the ball park of when you do the per-leg unbalanced computation. In this case that comes out to 24.74 kVA, which is a pretty small ballpark.
Looking at the formulas, these work out exactly.
kbarb
Joined Dec 29, 2008
6
Thanks a lot for your very fast reply.
And I like your sanity check exercise - I can always use a bit of that.
Thanks again,
Kent
KL7AJ
Joined Nov 4, 2008
2,229
Yikes....this is not as simple as it appears. But yes....it is probably unsolvable without knowing the power factor.
