Unable to supply enough voltage to relay
Discussion in 'The Projects Forum' started by spunky, May 17, 2012.
  1. spunky
    May 17, 2012
    Hi, this's my first project. i has checked my circuit, at the terminal that i wish to control the relay is only able to supply about 2.5 to 3 V only. my relay need 5V to on the switch. (this is the lowest V relay that i can found here)
    any idea how to on the relay?
    thank you for you guys answer
  2. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Can you post the circuit?
  3. mcgyvr
    Oct 15, 2009
    4,785
    973
  4. crutschow
    Mar 14, 2008
    13,473
    3,361
    Do you have any higher voltages available in the system?
  5. BJT_user
    Member
    Oct 9, 2011
    35
    8
  6. spunky
    May 17, 2012
    thank you all for your reply.. :)
    i cant use transistor anymore.
    @crutschow
    the voltage supplied to the circuit is about 9V...so it's enough for the relay. but at the point i want to use it to control the relay, the voltage is just about 2.5V..
