Unable to Collect ADC Result_PIC32MZ2048ECH144
Discussion in 'Embedded Systems and Microcontrollers' started by raviraj2992, May 6, 2016.
  1. raviraj2992
    May 6, 2016
    I have written code for ADC as below but i am not getting ADC output in ADC DATA (O\p Register). Please find code as below. Please suggest if any error or bug you get noticed.
    #include <p32xxxx.h>
    unsigned int Buffervalue;
    unsigned int i, j;
    int main(int argc, char** argv)
    OSCCON=0x00002200; //Configuring Oscillator
    ANSELGbits.ANSG15=0; //Setting pin as analog
    //Setting Calibration values to registers
    AD1CAL1 = 0xB3341210;
    AD1CAL2 = 0x01FFA769;
    AD1CAL3 = 0x0BBBBBB8;
    AD1CAL4 = 0x000004AC;
    AD1CAL5 = 0x02028002;
    /*Configuring AD1CON1*/
    AD1CON1= 0x00000000;
    /*Configuring AD1CON2*/
    AD1CON2= 0x00000000;
    AD1CON2bits.ADCSEL = 01; // Selecting Clock as System Clock
    AD1CON2bits.ADCDIV = 0000000; // Clock Divider
    AD1CON2bits.SAMC = 0x09;
    /*Configuring AD1CON3*/
    AD1CON3= 0x00000000;
    AD1CON3bits.ADINSEL= 0x17;
    AD1CON3bits.VREFSEL=0x1;
    /*Configuring AD1IMOD*/
    AD1IMOD= 0x00000000;
    /* Configure AD1GIRGENx */
    AD1GIRQEN1 = 0; // No global interrupts are used.
    AD1GIRQEN2 = 0;
    /* Configure AD1CSSx */
    AD1CSS1 = 0; // No channel scanning is used.
    AD1CSS2 = 0;
    /* Configure AD1CMPCONx */
    AD1CMPCON1 = 0; // No digital comparators are used. Setting the AD1CMPCONx
    AD1CMPCON2 = 0; // register to ?0? ensures that the comparator is disabled. Other
    AD1CMPCON3 = 0; // registers are ?don?t care?.
    AD1CMPCON4 = 0;
    AD1CMPCON5 = 0;
    AD1CMPCON6 = 0;
    /* Configure AD1FLTRx */
    AD1FLTR1 = 0; // No oversampling filters are used.
    AD1FLTR2 = 0;
    AD1FLTR3 = 0;
    AD1FLTR4 = 0;
    AD1FLTR5 = 0;
    AD1FLTR6 = 0;
    /* Set up the trigger sources */
    AD1TRG1 = 0; // Initialize all sources to no trigger.
    AD1TRG2 = 0;
    AD1TRG3 = 0;
    AD1TRG1bits.TRGSRC0 = 1; // Set AN0 to trigger from software.
    AD1TRG1bits.TRGSRC1 = 1; // Set AN1 to trigger from software.
    AD1TRG1bits.TRGSRC2 = 1; // Set AN2 to trigger from software.
    /* Turn the ADC on, start calibration */
    PB3DIVbits.ON=1;
    AD1CON1bits.ADCEN = 1;
    AD1CON3bits.CAL=1;
    /* Wait for calibration to complete */
    while (AD1CON2bits.ADCRDY == 0);
    AD1CON3bits.RQCONVRT=1;
    AD1TRG2bits.TRGSRC5=00001;
    while (1)
    /* Trigger a conversion */
    AD1CON3bits.GSWTRG = 1;
    /* Wait the conversions to complete */
    while (AD1DSTAT1bits.ARDY23== 0);
    if (AD1DSTAT1bits.ARDY23 == 1)
    /* fetch the result */
    Buffervalue = AD1DATA23;
    return 0;
  2. nsaspook
    Aug 27, 2009
    3,011
    2,356
    That chips (EC) ADC module is a train wreck.
    http://microchip.wikidot.com/faq:113
    From the Errata sheet item 43
    http://ww1.microchip.com/downloads/en/DeviceDoc/80000588J.pdf
