i am usig windows 7 and i am using keil uVision3 and burn many programs in 8051 microcontroller(p89v51rd2)....so if keil uvision4 is not working for you i will suggest you to try keiluvision3 once...
this is very good site for learning embedded systems you can contact the moderators of this site to solve any of your problem.once they solved mine problems too.
http://www.embeddedvalley.co.cc
have you tryed on linux OsTried on different PC running windows XP. Same problem again device driver not installed successfully. Installed drivers manually, no use.
Thanks a lot for your efforts. That 'Note' thing you did, why??? Seriously man. Right now I'm looking for an easy way out. So will probably buy new cableThere are few ckt if you can make it for your self
hope you have the good SMD soldering skills because FT232 is in SMD the driver for the same you may GOOOOOGLLLLLLLLLL
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
its datasheet is updated with V2.10 in march 2K12
http://www.google.co.in/search?q=circuit+diagram+of+serial+to+usb+converter&hl=en&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=mFNrUPC5Js-GrAeUloHoAQ&ved=0CCgQsAQ&biw=1348&bih=615
http://www.google.co.in/search?q=ft232r+usb+uart+driver+download&aq=3&oq=ft232&sugexp=chrome,mod=16&sourceid=chrome&ie=UTF-8
http://zekepomi.over-blog.com/article-98682665.html
Note:--
Please note
1>. i have not try ed this ckt. nor tested and not assembled by me i came to know only through net surfing
2>. I don't take any response ability of any kind of virus through the link as it's google search link and there respective web site
Best of luck even Now i am planing to make the same even i don't need it only for experimental fun of SMD
First heavy shock Rs 450 μSoldering iron For SMD soldering Rest in coming weeksssssssssssssss
but i will let you know if it is completed successfully ofcourse not with out all ACC help
hats of to ACC gave me the reason to start the exp. with SMD
by Aaron Carman
by Duane Benson
by Duane Benson
by Duane Benson
