I don't think there is any accuracy difference between measuring the time-constant and measuring the frequency. So it depends upon which is the simplest and/or most reliable.
You could do continuous time-constant measurements and perform a simple running average if you are worried about false readings or noise.
Will the microprocessor circuit see much of a temperature change?
