UltraSonic Radar
Discussion in 'The Projects Forum' started by LED Man, Feb 26, 2009.
  1. LED Man
    Thread Starter Active Member
    Jan 15, 2008
    62
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    All parts are pretty standard.
    The only special parts are the two tranducers for 40 kHz.
    Greetings,
    Bertus
  3. LED Man
    Jan 15, 2008
    62
    This is my first project so I really don't have much experience. Would digikey have what I need?
    I found this which looks perfect - http://www.sunrom.com/p-74.html
    Also, where can I find a PCB or breadboard (which is better) to build the project on?
    Thanks again, sorry for the noob q's
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Why don't you buy the kit that has everything that is needed.
    C3 is not needed.
  6. LED Man
    Jan 15, 2008
    62
    Where do I find the kit??
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    I noticed that C1 is shown shorting the input.
    SmartKit is from Greece but are available in many countries. I saw some being sold in a shop in my city on the other side of the world from Greece. Look for them in Google.
  8. LED Man
    Jan 15, 2008
    62
    So what does that mean with C1? Did they do something wrong?
    I'd rather put this together myself, I think I'll skip getting the SmartKit, thanks though
    In terms of input, should I also get something like this? http://media.digikey.com/photos/CUI Photos/PJ-102B.jpg
    Or is it included but I just don't see it. Thanks
  9. LED Man
    Jan 15, 2008
    62
    Guys, I have no idea what to get for these parts. When I search for these parts a million items come up. Any help? Thanks.
    TR1, 2, 3 = BC547 , BC548
    IC3 = 4093 C-MOS
    P1 = 10 KOhm trimmer
    P2 = 47 KOhm trimmer
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    That is a power supply jack.
  11. LED Man
    Jan 15, 2008
    62
    Right, so I'd use that for a 12v input from an outlet to the board right?
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  13. LED Man
    Jan 15, 2008
    62
    Wow, thank you so much.
    For future reference, how did you go about picking each component? It was a bit overwhelming having a million items pop up when I looked up those parts. Thanks again!
    Also, about the power jack. If I have a 120v ac power converter to 10v DC from the wall, that jack I put up before would work to power the board right? Given I mount the unit near a wall jack.
  14. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    To find the components on the website of digikey I used diffrent methods.
    The transistor I filled in in the search window.
    The CD4093 also.(I know there are CD and HEF as preface).
    The potmeters I looked in the list product index and looked for trimmers, then I have choosen BOURNS as a brand, single turn, through hole, 3386 sealed, then the value.
    I have choosen Bourns because we use then a my work also (the 25 turn types).
    Greetings,
    Bertus
