UltraSonic Cleaners
Discussion in 'General Electronics Chat' started by R!f@@, Aug 7, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    Does any body has a DIY Project for this ?
    My ones IC is blown literally, so me dunno what to put there.
    Any Ideas ?
  2. BMorse
    Sep 26, 2009
    2,675
    234
    which kind do you have? a "real" ultrasonic cleaner, or one of those cheap vibrating ones??
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    Now u have said, I think it's the later.
    Is it possible to make this better?
  4. BMorse
    Sep 26, 2009
    2,675
    234
    you can probably make one yourself if you had an actual ultrasonic transducer......
  5. R!f@@
    Apr 2, 2009
    8,793
    771
    U shud know I have one due to the fact that I have a broken one.
    Any Schema's ?
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    If, like you say, it is just one of the cheap vibrating kind, it won't have an ultrasonic transducer. They usually just have a coil and a metal diaphragm, which may be the tank itself. On the other hand, if, on the bottom of the tank, there is a module of sorts epoxied to the tank, it is probably the ultrasonic transducer.
  7. R!f@@
    Apr 2, 2009
    8,793
    771
    I know tht guys.
    The transducer fell off.
    Now I had it glued to the tank bottom with new wires soldered. I used epoxy, which hardens to rock solid..
    The IC blew it's topside to kingdom-com.
    I read few articles and it seems there are variable frequency ones. Mine has just a PB switch, nothing else.
    So, if I can get my hands on a good HF driver circuit tht can very from intensive to gentle cleaning, it would be awesome. I can make a heater regulator to heat the solvent.
    The transducer is like a big coin. The Godzilla version of a piezo...no?
  8. Mad Professor
    Apr 15, 2009
    133
    R!f@@: I have a Kerry KC2 UltraSonic Tank.
    Would you like some pictures of the PCB and Schematic?
    R!f@@ likes this.
  9. R!f@@
    Apr 2, 2009
    8,793
    771
    I would like tht very much, Mad Prof.
  10. Mad Professor
    Apr 15, 2009
    133
    Do you have an e-mail address that I can send the files over to?
    Best Regards.
  11. R!f@@
    Apr 2, 2009
    8,793
    771
    Just PMed.
  12. shortbus
    Sep 30, 2009
    4,098
    1,698
    @MadProfessor, why not post the schematics here to help any one else to repair or build one? Thanks
  13. R!f@@
    Apr 2, 2009
    8,793
    771
    I guess the company will sue him....! :cool:
    I got the pics of my one.
