Is the circuit still noisy with the mic not fitted?......If so, then it could be the extra stray capacitance introduced by the stripboard itself is cauaing some instability.
It might be wise at this stage to follow the 'golden rule' of project prototypes. (This is from the 'old days' -- and was especially important for radio frequency projects!) :
Once you have a working prototpye of an experimental circuit you leave it working as a reference. You then build another, knowing that you have a working example to compare you new circuit against.
Although simulation software is very useful, it doesn't always deal well with the real world 'quirks' that an actual prototype will throw up at you....and as you progress - and things get worse before they get better! - then the original working version keeps reassuring you that it can work for real... even if it's real 'birds nest'.
These actual hardware prototypes are where you learn the so called 'black arts' of analogue electronics..... the real thing doesn't always work quite like the simulation said it should!...there can be elements of trial and error, with things like power supply de-coupling, and stray capacitance...
As an aside, I'm wondering how, without any 'tuning' at all (other than high pass filters to remove low frequency audio) you are intending to discriminate your bat calls from the whole bunch of other ultrasound there is out there?
For example, some rodents generate a lot of ultrasound, and you might be surprised at just how much grass and trees generate... especially on a windy night!!
But first things first. Is it the circuit that's noisy... or is the microphone picking up a whole bunch of unwanted ultrasound in the environment and actually doing its job and amplifying it?
