I am trying to design an circuit to amplifying a mic signal (~15kHz-100kHz) to feed it into a microcontroller (which will use the input for Bat-Detection an Logging). With lots of help from google and this forum I finally came up with a circuit that seems to work (breadborad and simulator). But since I have no experience with this kind of circuits I was wondering if someone with more knowledge could look over my design (are there some 'obvious' beginners mistakes? could the design be improved? Any potential problems?) before I produce a PCB.
My Idea was to amplify the signal from the mic and filter out low frequencies. After that I used a comparator to create a 'rectified' signal for the microcontroller. For the OpAmp's I used two OPA2344.
Thanks for your help!
