So I bought this and I got more than I bargained for.
It says 5 modes
Strong Brightness. - which works after 1000 clicks
Medium Brightness - which works after 500 clicks
Low Brightness - Which never fails to work
Strobe - Which works after around few clicks
SOS - Whatever that means.
I bought it cause I needed a bright light to work with where ever I go. Needed it to be rechargeable, since I had plenty of Li-on's, this particular model was tempting.
I am having a hard time trying to get strong brightness mode. It always tend to flash and blind my eyes every now and then, and it always goes to low brightness mode after a second when I switch it on.
I do not need all those fancy modes, so I thought I just hook it up directly by bypassing what ever is inside the torch, so took it apart and I found zip.
Just the cree led and the switch, so what gives.
Is the LED fault that it does not stay at full brightness.
I checked the switch and it just works as a switch. DUH!!
What is this CREE thing anyway?
Is it just a high brightness LED, rated at 3.7V or so?
I do not want to blow the led so I am asking around, since I never tampered with a cree led before.
How can I get the maximum brightness out of this thing.
Any suggestions folks.
It says 5 modes
