Ultra sonic sensor
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Nov 4, 2014.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I was working on Ultra sonic sensor for that i need to calculate the distance from it, i have this code working fine in my PIC16F877 the LED is connected for signal (working or not)
    anyway i need to know the use of 58 value, actually it was float so, i convert to decimal.
    LCD will be added that part i will do myself.
    but i want to increase it sensitivity. more and need to know the CALCULATION 20Mhz Crystal is being used.
    a = a/58; //Converts Time to Distance
    a = a + 1; //Distance Calibration
    Fosc is the oscillator frequency, here we are using 8MHz crystal hence Fosc = 8MHz.
    Time = (TMR1H:TMR1L)*(1/Internal Clock)*Prescaler
    Internal Clock = Fosc/4 = 8MHz/4 = 2MHz
    Therefore, Time = (TMR1H:TMR1L)*2/(2000000) = (TMR1H:TMR1L)/1000000
    Distance Calculation
    • Distance = Speed * Time
    • Let d be the distance between Ultrasonic Sensor and Target
    • Total distance traveled by the ultrasonic burst : 2d (forward and backward)
    • Speed of Sound in Air : 340 m/s = 34000 cm/s
    • Thus, d = (34000*Time)/2, where Time = (TMR1H:TMR1L)/(1000000)
    • Therefore, d = (TMR1H:TMR1L)/58.82 cm
    • TMR1H:TMR1L = TMR1L | (TMR1H<<8)
    Code (C):
    1. #include <htc.h>
    2. __CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
    3. #define _XTAL_FREQ 20000000
    4. main(){
    5.   TRISB = 0b00010000;
    6.    RB5=1;
    7. __delay_ms(1000);
    8. RB5=0;
    9. __delay_ms(500);
    10. RB5=1;
    11. __delay_ms(1000);
    12. RB5=0;
    13. __delay_ms(500);
    14.
    15. while(1){
    16.
    17.
    18.
    19.
    20.
    21. int a;
    22.   T1CON = 0x10;  //Initialize Timer Module
    23.   TMR1H = 0;  //Sets the Initial Value of Timer
    24.   TMR1L = 0;  //Sets the Initial Value of Timer
    25.
    26.   RB0 = 1;  //TRIGGER HIGH
    27.   __delay_us(10);  //10uS Delay
    28.   RB0 = 0;  //TRIGGER LOW
    29.
    30.   while(!RB4);  //Waiting for Echo
    31.   TMR1ON=1;  //Timer Starts
    32.   while(RB4);  //Waiting for Echo goes LOW
    33.   TMR1ON=0;  //Timer Stops
    34.
    35.   a = (TMR1L | (TMR1H<<8));  //Reads Timer Value
    36.   a = a/58;  //Converts Time to Distance
    37.   a = a + 1;  //Distance Calibration
    38.   if(a>=2 && a<=400)  //Check whether the result is valid or not
    39.   {
    40.   RB5=1;
    41.   }
    42.   else
    43.   {
    44.   RB5=0;
    45.   }
    46.   __delay_ms(400);
    47.   }
    48. }
    49.
    50.
    51.
    52.
    53.
    54.
    55.
    56.
    57.
    58.
    59.
    60.
    61.
    62.
    63.
    64.
    65.
    66.
    67.
    68.
    69.
    [/CODE]
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How to use this to show distance in Cm
    sprintf( Distance, "%dcm",a);
    Code (C):
    1. #include <htc.h>
    2. #include <stdio.h>
    3. #include <stdlib.h>
    4.
    5. __CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
    6. #define _XTAL_FREQ 20000000
    7.
    8. #define DATA PORTC
    9. #define EN RB7
    10. #define RS RB6
    11. #define N 1
    12. #define M 1            // DELAY  FOR LCD
    13.
    14.
    15. unsigned long number=0;        // Number MUST be a long for fixed point
    16. int ch=0;
    17. unsigned char LCDbuffer[17];
    18. unsigned char m[21]="WATER LEVEL";
    19. unsigned char n[21]="OUT OF RANGE";
    20. void LCDcmd(char x), LCDdata(char x);
    21. void LCD_goto(char line, char column)    ;
    22.
    23. void LCD_printR(char *str);
    24. main(){
    25.   TRISB = 0b00010000;
    26.
    27.     TRISC=0X00;
    28.
    29. PORTC=0X00;
    30. PORTB=0X00;
    31. __delay_ms(50);
    32.      LCDcmd(0x38); // init
    33.     __delay_ms(N);
    34.     LCDcmd(0x38); // init
    35.     __delay_ms(N);
    36.     LCDcmd(0x38); // Function set
    37. __delay_ms(N);
    38.      LCDcmd(0x06); // Cursor move increase, no display shift
    39.     __delay_ms(N);
    40.     LCDcmd(0x0C); // Display on, cursor off, not blinking
    41.     __delay_ms(N);
    42.     LCDcmd(0x01); // Clear display. goto pos 1
    43.     __delay_ms(N);
    44.
    45.     RB5=1;
    46. __delay_ms(1000);
    47. RB5=0;
    48. __delay_ms(500);
    49. RB5=1;
    50. __delay_ms(1000);
    51. RB5=0;
    52. __delay_ms(500);
    53.
    54. while(1){
    55.
    56. LCD_goto(1,1);
    57.         LCD_printR(m);
    58.
    59.
    60.
    61. int a;
    62.     T1CON = 0x10;                 //Initialize Timer Module
    63.     TMR1H = 0;                  //Sets the Initial Value of Timer
    64.     TMR1L = 0;                  //Sets the Initial Value of Timer
    65.
    66.     RB0 = 1;               //TRIGGER HIGH
    67.     __delay_us(10);               //10uS Delay
    68.     RB0 = 0;               //TRIGGER LOW
    69.
    70.     while(!RB4);           //Waiting for Echo
    71.     TMR1ON=1;               //Timer Starts
    72.     while(RB4);            //Waiting for Echo goes LOW
    73.     TMR1ON=0;               //Timer Stops
    74.
    75.     a = (TMR1L | (TMR1H<<8));   //Reads Timer Value
    76.     a = a/147;                //Converts Time to Distance
    77.                       //Distance Calibration
    78.     if(a>=2 && a<=400)          //Check whether the result is valid or not
    79.     {
    80.
    81.        RB5=1;
    82. LCD_goto(2,1);
    83.
    84.         LCDbuffer[0] = ((a % 1000) / 100)+ 48;
    85.         LCDbuffer[1] = ((a % 100) / 10)+ 48;
    86.         LCDbuffer[2] = (a % 10) + 48;
    87.     LCDbuffer[3] = 0;
    88. LCDbuffer[4] = 0;
    89. LCDbuffer[5] = 0;
    90. LCDbuffer[6] = 0;
    91.      [B]   LCD_printR(LCDbuffer);
    92. sprintf(LCDbuffer, "level = %d",a);[/B]
    93.
    94.
    95.
    96.
    97.     }
    98.     else
    99.     {
    100.
    101. LCD_goto(2,1);
    102.         LCD_printR(n);
    103.       RB5=0;
    104.     }
    105.     __delay_ms(400);
    106.   }
    107. }
    108.
    109.
    110.
    111.
    112.
    113.
    114.
    115.
    116.
    117.
    118.
    119. void LCDcmd(char x)
    120.     {
    121.     __delay_ms(N);
    122.     RS=0;
    123.
    124.     __delay_ms(M);
    125.     EN=1;
    126.     __delay_ms(M);
    127.     DATA = x;    // Command data
    128. __delay_ms(M);
    129.     EN=0;
    130.     __delay_ms(M);
    131.     }
    132. void LCDdata(char x)
    133.     {
    134.     RS=1;
    135.
    136.     __delay_ms(M);
    137.     EN=1;
    138.     __delay_ms(M);
    139.     DATA = x;  //  Print data
    140.     __delay_ms(M);
    141.     EN=0;
    142.     __delay_ms(M);
    143.     }
    144. void LCD_goto(char line, char column)        // combines line and lineW
    145.     {
    146.     unsigned char data = 0x80;                // default to 1
    147.     if(line == 2)data = 0xc0;                // change to 2
    148.     data += column;                            // add in  column
    149.      LCDcmd(data);
    150.     }
    151.
    152. void LCD_printR(char * str)             // This passes the start of a RAM character array
    153.     {                                // by default the pointer points to data section
    154.     while(*str != 0)                // while the character pointed to isn't 0
    155.         LCDdata(*str++);            // print out the character, then increment
    156.     }
    157.
    158.
    159.
    160.
    161.
    162.
    163.
    164.
    165.
    166.
    167.
    168.
    169.
