ultra low dc-dc boost converter
Discussion in 'The Projects Forum' started by JNG44, Dec 19, 2013.
  1. JNG44
    Dec 19, 2013
    5
    Hi i am looking to design a solar cell powered dc-dc boost converter and i am having difficulty finding recent infomation on the latest technology and the issues in this field of power electronics... can anyone please assist?
  2. wayneh
    Sep 9, 2010
    12,403
    3,252
    Take a look at the IC manufacturers such as Linear and International Rectifier. They'll have products in this area and may also have pre-commercial, experimental "products" they will share.
  3. BobTPH
    Jun 5, 2013
    807
    121
    TI also has a lot of good DC-DC converter chips.
    Bob
    wayneh likes this.
  4. JNG44
    Dec 19, 2013
    5
    Thanks for your help, i'll look into it. Do you know the most efficient way to boost 0.3v to 3v? I have looked on digikey and read a few power electronic books which gave some ideas how to simulate several designs on multisim but it only stepped up to 0.5v?
  5. BobTPH
    Jun 5, 2013
    807
    121
    A Joule Thief circuit might operate as low as .3V, but I am not sure. That is a very low voltage to start with, I don't know of any boost converter chips that go down that low. You might want to look up "energy havesting".
    Bob
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The price for boosting the voltage by a factor of 10 is lowering the current output, at 3 volts, by a factor of more than 10. In simple terms your first "back-of-the-envelope" calculation is that "Power In" is required to be "Power Out" DIVIDED by the Efficiency. Efficiency of a DC-DC converter will ALWAYS be a number in the interval [0, 1). In particular, the efficiency can NEVER be equal to 1.
    Example: You want 3V @ 100 milliwatts. That is a current of 33.3... milliamperes. So far so good. Assume a DC-DC converter exists that has an 80% efficiency. So 100 milliwatts / .8 = 125 milliwatts. Still with me? So 125 milliwatts at 0.3 V requires a current of -- are you ready? -- ≈ 417 milliamperes. So finally we see that 417 milliamperes / 33.3 milliamperes ≈ 12.51, and unless I missed something 12.51 is > 10 period, full stop.
    Now the question of weather you can build a DC-DC converter that will work down to 0.3V remains to be seen.
  7. JNG44
    Dec 19, 2013
    5
    Thanks Bob I will look into energy harvesting and the joule thief design.
    Papa, that was a very interesting and helpful analysis of my problem at hand. I do have room to manoeuvre the input voltage up to 1 V and have researched different circuit designs, which do say 0.3 is too low.... Do you have an idea how to build an efficient circuit that will step up from 1 to 3-5v?
  8. bance
    Member
    Aug 11, 2012
    315
    34
    Shariar, did a pretty good video on this sort of thing!
    HTH Steve
    Bernard likes this.
  9. BobTPH
    Jun 5, 2013
    807
    121
    Your chances are much better at 1V. A Joule thief would operate pretty effectively at that level. At 0.3V, it would be very difficult to get any reasonable efficiency.
    Bob
  10. ronv
    Nov 12, 2008
    3,404
    1,495
  11. MrChips
    Oct 2, 2009
    12,652
    3,461
  12. The Electrician
    Oct 9, 2007
    2,301
    339
    The LTC3105 internal schematic shows a low voltage start-up block, but I don't see any such thing in the LTC3108 internals. How does it start up? With only 20 mV input?
  13. JNG44
    Dec 19, 2013
    5
    Thanks for the reply guys, especially loved the video.... Thanks again.
    Energy Harvesting is something I have looked into and I would like to know who or where would be the best place to find the most up-to-date published articles on the topic. would it be manufacture websites or magazines.. etc?
  14. BobTPH
    Jun 5, 2013
    807
    121
    I take back my comment about not being able to get much efficiency at 0.3V input. Very cool.
    Bob
