I got 3 awesome machines for free. My generous benefactor is the honorable dfletch (Doug) from this forum, and I got these in response to his post here :http://www.hobby-machinist.com/showthread.php/9450-Free-machines).
Having never seen the machines, I just rented a trailer and drove up there ASAP to snatch them up.
First up, The power hacksaw. It's an excelsior 2-A, I estimate it's older than 1930, probably closer to 1900. Just a layman's guess from looking at the design. If anybody knows better, or knows anything at all about it, let me know.
Doug said it works, but is super worn out. It fell over while being loaded and now the main sheave is cracked and will need to be replaced, along with all the bushings. I really like thing. I am going to do a full restore on it, sandblast, paint, the whole 9 yards.Next, the bandsaw. I can't find a model number on it anywhere, and the only reason I know it's a Forte brand is because it says to "only replace with quality Forte brand blades." It weighs probably 500lbs or more. it's missing a gear, but otherwise I don't see anything preventing it from running. Nothing froze up, bearings good. It has a cutting fluid tank and pump. I (again, layman) estimate it's 1970's vintage. Again, if anybody knows anything about this machine, I would appreciate the info.
And finally, the Lathe. This is an Imperial brand lathe, made in Italy. I measured 8.5 inches from center of the headstock to the ways, so I guess that makes it a 17" swing. It's about 9ft long. Nameplate on the motor says 1953. I have no idea what the model# is, cannot find one anywhere on the lathe. The tailstock that came with it is not the correct tailstock, but can be made to work; it is facing the wrong direction and 1/2" too low. I cannot find anything on the internet about this lathe, and I have only seen one other person on the internet that has one (metal lathe of this brand, much less model), and he also cannot find any information on it. Doug also found zero information. It has a taper attachment, 3 jaw, and 4 jaw chucks. It is missing a gear, the motor is burnt up, and the control wiring is missing. Missing the slide that the tool post bolts to. got lots of surface rust, and QC gear handle is broken off. The electrical portion should be a breeze for me, but this will be the most extensive and challenging mechanical project I have ever attempted. I don't know the extent of it, as I have not really looked at other than loading and unloading it. and once more, if anybody has information, I'm greatly appreciative. Here's some pics:
Here's some pics of the loading and unloading process. It took 8 hours for me to unload it with an engine hoist and a comealong jack. I don't know how much this lathe weighs, but I estimate it weighs at least as much as my truck (~4000lbs). Doug's forklift stalled out a few times trying to put it on the trailer. Leaving Doug's shop:
arriving at my home:
