ULN2803A multiple voltages
Discussion in 'General Electronics Chat' started by jim77, Nov 23, 2008.
  1. jim77
    Nov 21, 2008
    7
    Hi everybody...:)
    I have had a search but not really found the answer..
    I am using a Pic Micro/ ULN3803A to drive 4 x 24v (approx 60mA each) Led display modules, which works fine. I have them connected as below ( common unconnected)
    24V-----Led Module------collector on ULN2803A
    Is it possible to the same on another output of the same IC, but at 5v?
    Also, I would like to use PWM on one of the spare inputs to supply a chain of IR Leds @ 12v 60mA.
    I have done all of the above at one time or another, but not all on the same IC
    Any advice/previous experience greatly appreciated
  2. Ron H
    Apr 14, 2005
    7,050
    657
    You should be able to use different supply voltages. I would connect the common pin to the highest voltage. It will work if you leave it unconnected, but you could see some transient effects if you were running at high frequency.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just to qualify RonH's input...
    The various voltages must all have a common ground point.
    If they don't, you will have big problems.
  4. jim77
    Nov 21, 2008
    7
    Thx Ron n wookie :)
    For sure, a common ground is important, I was wondering if anybody had problems with maybe a nearby input being pulsed along with the one I intended..
    I'll knock it up on a breadboard, see what happens, and let you know.
    I would have thought it would be OK, I was just trying to make use of a couple of spare outputs on the board
    Thx again
    Jim
