uln2004-water-level-indicator
Discussion in 'The Projects Forum' started by BBQ, Aug 10, 2014.
  1. BBQ
    Jan 22, 2014
    23
    Hi there I'm looking for some help...I built the circuit and working fine however what I would like to do is once led 2 is no longer illuminated the water has drained below P2 to activate the buzzer from that point.
    Cheers
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Another inverter connected to pin 11 to will drive a buzzer connected to +V.
  3. BBQ
    Jan 22, 2014
    23
    Any idea for the inverter components to implement with this ?.
    Cheers
  4. Dodgydave
    Jun 22, 2012
    5,134
    767
    Just connect the buzzer + to pin 11 and ground, so that when the led goes out the buzzer sounds.
  5. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Could you abandon P1 and use inverter 7 in a new role to operate the buzzer?
  6. BBQ
    Jan 22, 2014
    23
    Alec T that was my first consideration but the way I have it laid out on the board I will use all the inputs for this application....at point 2 is where I need the buzzer to activate at a later date I may change that though.
  7. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Use a ULN2805 has 8 gates, take the output of P2 to the spare inverter and the output to the buzzer P7.
    Max.
  8. BBQ
    Jan 22, 2014
    23
    MaxHeadRoom yes that's the IC I should have used but it's made up now and I bought 20 on fleabay so I'm sort of in a jam lol...cheers
  9. BBQ
    Jan 22, 2014
    23
    Dodgydave when the led is on so is the buzzer.
  10. ScottWang
    Aug 23, 2012
    4,924
    777
    You can try the circuit as below, I'm not sure about the current of Buz, if the current less then 33mA then you can using 2N3904, if the current more then 33mA, then you should pick up the bjt for some more current.
    BBQ likes this.
  11. BBQ
    Jan 22, 2014
    23
    ScottWang Thats exactly what I was thinking of but not the experience to solve....and this will work when the LED 2 turns off....Thank you very much appreciated....cheers
