ULN2003a with Arduino for a step by step motor
Discussion in 'Embedded Systems and Microcontrollers' started by Yokad912, Jan 2, 2016.
  1. Yokad912
    Jan 2, 2016
    Hello!
    I'm trying to control a step by step motor with my arduino Uno. I added a ULN2003a between them to have more current in my motor.
    I wanted to test the ULN2003a a bit before I use it on my motor. I made a little circuit with a switch and a LED. (picture joined)
    But the ULN2003a is not responding as I was expecting. The tension between A and B is -0.5 V without the switch OFF and
    4.4 V when it's ON. The LED is not on. (I tested it, everything except the ULN2003a works).
    Is the chip dead?
    Or have I made a mistake?
    Thank you for your help!
    Christian
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    You have made a mistake, the chip acts like a switch to ground, so at minimum the LED is backwards and should go to the +5 volts.
    When I get to my pc I will check a few more things I can't see on my iPad.
    Edit: That should be it. I doubt your mis connections damaged your part.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
  4. Yokad912
    Jan 2, 2016
    I understand now! It works! Thank you all!
    ErnieM likes this.
