Hi Gang,
I have a circuit with three outputs that switch channels of a ULN2003 Darlington array to drive an RGB LED Module - one output to each color.
Right now, it works perfectly. I want to add another module and have a question. can I just tie each output to two of the 2003 channel inputs, then tie the outputs to the two separate modules? Or do I need something between the 2003 inputs?
Here's what I have in mind:
This way? or something else?
Thanks!
- a -
Thanks!
- a -
