uln 2803
Discussion in 'General Electronics Chat' started by FroceMaster, Apr 13, 2015.
  1. FroceMaster
    Jan 28, 2012
    402
    Quick ? about this uln2803
    can i just use it as a replcement for normal transistor.
    Like in the schem..
    most i think is the pin 10, is that commond ground for all transistors ?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    As long as you realize that the innards are more complicated than a transistor:
    Pin 9 is E (gnd). Pin10 is COM (used as a snubber for inductive loads)
  3. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Bi-polar Darlington configuration, fairly high impedance input.
    Max.
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Don't forget those devilish little details - you need double the Vbe to turn them on, and you can't saturate a Darlington.
  5. eetech00
    Jun 8, 2013
    678
    116
    It depends on how you intend to use it. Post description and/or schematic please?
    eT
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    When you using bjt as a driver then maybe you can using uln2803 to replace it.
    The uln2803 provided the collector-current rating of each Darlington pair is 500 mA, and also the total current is the same, in most situations that you just using the current less then I = 500 mA * (1/3) = 166.67mA, whatever each or total, the better way is to using the total current as I = 500 mA * (1/5) = 100 mA for the heat issue, what is the best balance point for the current and heat, when the IC can be touch with fingers and it just has a little warm, but not hot.
  7. FroceMaster
    Jan 28, 2012
    402
    foforgot the Picture. just think of 5 volt as TTL output
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Do not ground pin 10. Either tie it to +5V, or let it float.
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    You can see the practical application as below, uln2003 is the same as uln2803 just less one driver, you can let the inputs floating or connected to ground, the common pin of diode can be float or connect to +5V, when the load is relay or coil must be connected to +5V.
    FroceMaster likes this.
