I'm thinking of using this circuit to drive 5 of these:
http://www.rapidonline.com/netalogue/specs/55-1310.pdf
I think that if I set the pin to an input (high impedence) that I should get my constant current and set it low that should turn the LEDs off.
Do you think it will work?
Also I've shown the LED as 3 LEDs because there are 3 in 1 package. Unfortunately the datasheet isn't really clear but I think they are not internally connected.
Would it be safe to assume that they are closely enough matched that I can use one driver per package or do I need seperate drivers?
