Uart to int in mikroc
Discussion in 'Embedded Systems and Microcontrollers' started by varunme, Mar 21, 2012.
  1. varunme
    Sep 29, 2011
    59
    How can i convert char from UART to int in mikroC ?
    My below code to loop the number of times according to the character send from uart, does not work, can anybody help ?
    Code ( (Unknown Language)):
    1.
    2.
    3.
    4. void main(){
    5. unsigned char txt[2];
    6. int y,rot;
    7. char on[10];   // char table to store received string
    8. int intme;
    9. trisb=0x00;
    10. portb=0x00;
    11.
    12.     UART1_Init(9600);
    13.
    14.
    15.
    16. // Check if character is ready for reading and read it.
    17.         if (UART1_Data_Ready() == 1) {
    18.         on[0] = UART1_Read();   // read one character from uart
    19.         on[1] = '\0';           // insert terminating zero
    20. }
    21.
    22.
    23.
    24.           for(rot=0; rot<=atoi(on );  rot++)
    25.           {
    26.
    27.                  PORTB=0b00010000; delay_ms(200);
    28.                  PORTB=0b00001000; delay_ms(200);
    29.
    30.                  }
    31.                  }
    32.
    33.
  2. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Well, for one thing, the number of braces does not match. Does this even compile?
    Is UART1 intrinsic or does it require an include? Where are the fucntions defined?
    As for the line 'for (rot=0; rot<=atio(on ); rot++)' ??? Where is atio() defined? Which value of on[] are you after? only 0 and 1 have been loaded.
    Well, don't quite know what to say.
  3. varunme
    Sep 29, 2011
    59
    atoi is inbuilt function
    Uart1 also inbuilt
    the braces are matched and compiled, but when i copy pasted, it didnt matched
    i want the dynamic values of on[] . that is whatever i sent from uart.
  4. hexreader
    Apr 16, 2011
    250
    82
    Which PIC are you using?
  5. hexreader
    Apr 16, 2011
    250
    82
    You fail to wait for a character to be received.
    You check once to see if a character is ready, but at start-up, first time through, there will be no character ready.
    You need to keep checking UART ready, and do not continue until a character is ready
    varunme likes this.
  6. varunme
    Sep 29, 2011
    59
    i am using 16f877a
  7. varunme
    Sep 29, 2011
    59
    yes, i made it loop onetime,
    but how can i make it continous loop ?
  8. varunme
    Sep 29, 2011
    59
    ohh , yes , its working now
