UART Rx Preemption in Cortex M0
Discussion in 'Embedded Systems and Microcontrollers' started by arunjoec, Jul 14, 2016.
  1. arunjoec
    Jul 14, 2016
    Sir,
    I'm using UART 2 as a higher priority interrupt than other UART ports in Nuc-220 ARM Cortex M0
    1. I want to know what happen if I use UART 2 Tx while inside a UART2 Rx interrupt Service Routine, will it become a pending interrupt or trigger an Tx interrupt at the same time?
    2. I'm using the UART2 Tx inside a UART2 Rx interrupt to communicate with a GSM module,so for each commands I send I would also get replies and these Replies will also create UART2 Interrupt of same priority.
    In this case will it preempt the current Rx Interrupt or become another Rx pending interrupt? or is there any ways to configure this in the Nuc-220 MC?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    I would consult datasheet. It should list interrupt priority.
