uA741 vs LM324
Discussion in 'General Electronics Chat' started by Aisha.Raj, Jun 29, 2013.
  1. Aisha.Raj
    Nov 22, 2012
    14
    Can someone pls guide me as to which is a practically better op amp , the uA741 or the LM 324 when it comes to using an op amp in a pulse generator circuit ( to generate square pulses of width varying from 0.1ms to 1s and varying duty-cycle from 25% to 75 % ) ....??? What could be the major concern issues when i am choosing the op amps ....?? I mean when i used either of them i was not able to pin point major differences in the waveforms...
  2. t06afre
    May 11, 2009
    5,939
    1,222
    That will depend on the circuit. You should post that. The LM324 is a single supply opamp. So that may be the best option, I think. But both opamps are kind of outdated. By the way why not use a LM555 type circuit
  3. Aisha.Raj
    Nov 22, 2012
    14
    the circuit is in the attachment and have used LM324N in the design
      File size:
      93.8 KB
      104
  4. Aisha.Raj
    Nov 22, 2012
    14
    umm...v have been specifically asked to design a pulse generator using op amps which operate off ± 10 V ...also while rigging up the circuit , i have given ± 10 V for the LM324 as supply , i havent given it a +Vcc and Grd as supply....
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Ah.. so this homework. Is your observation based on a real world circuit, or just simulation? Both opamps will operate fine at +/- 10 volt. But the 741 do have slightly higher gain bandwidth product (GBW). And that will maybe be a plus in such application
  6. Aisha.Raj
    Nov 22, 2012
    14
    yes it is...i have tried practically implementing both circuits and i am not able to tell difference (if there are any)...both have comparable slew rates also (0.5 V/us for 741 and 0.4V/us for LM324)...well the hardware looked more compact in case of 324 since it was a quad IC and i had js 1 such one in my breadboard compared to 3 when i used a 741.....
  7. t06afre
    May 11, 2009
    5,939
    1,222
    If you can not se much deference if any at all. And you think using a LM324 gives you a more compact design and less wiring. Then just go for LM324. As this would a valid argument in real world electronics circuit design. But you should discuss your choice in your final report. Just like you did in post #6
    Aisha.Raj likes this.
