On my car I have an indicator module that has a U2043B IC inside (datasheet attached).
The system has a bulb outage detection by using a shunt resistor in series with the incandescent bulbs. When it detects a bulb outage the flash rate doubles.
As I would like to move over LEDs to replace the bulbs, I would like to modify my indicator module box to accomodate this.
It's fairly straight forward how it all works, but I would like a little guidance from you guys (the experts) if my logic adds up.
The standard shunt resistor is 30 milli-ohm, which incidentally is the same resistance described in the datasheet calculations.
I was thinking if I replace the shunt resistor for a much higher resistance for the LEDs, say 800 ohms (100mA draw from LEDs) then this would be the simplest way to solve the problem....
I have also attached a photo of the insides of the unit for you to see how simple it looks and how things all relate.
Thanks!
Dominic
Thanks!
Dominic
