Thread Status:
Not open for further replies.
  1. yasir_66
    Thread Starter Active Member
    Jun 25, 2009
    71
    these are schematics.Plz audioguru redesign receiver ckt. & tell me which transistor# is wrong biased?
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    No schematics are evident, try reposting them.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The schematics were saved and were posted as small fuzzy JPG file types. JPG has losses that make the image fuzzy so its numbers cannot be seen.
    You should have saved and posted the schematics as a very clear PNG file type and made larger.
    The first transistor in the receiver is biased so that it is almost saturated. Also the values for its base bias resistors are too high.
    Transistors should not be used as a preamp today, a low noise wide bandwidth opamp should have been used.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    If you still want to use that receiver circuit, I redesigned it for you. It is optimized for a 40kHz piezo ultrasonic transducer. If you want to use a tweeter, it will need an input coupling capacitor.
    It has a lot of gain at the Q2 collector (≈40dB), even with the gain pot set at 10k. With the gain pot set at zero, the gain iis about 70dB. You might need to use a different gain control scheme if the gain is too high.
  5. yasir_66
    Jun 25, 2009
    71
    ok thnx buddy.yes i have piezo transducer in which metal surface is shorted to gnd.
  6. yasir_66
    Jun 25, 2009
    71
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
Thread Status:
