1.
Conduction of N-type electrons in in the conduction band.
http://www.allaboutcircuits.com/vol_3/chpt_2/5.html
2.
A realistic machine most often looses some of its input energy as heat in transforming it into the output energy stream.
http://www.allaboutcircuits.com/vol_3/chpt_1/3.html
3.
The cross-section in Figure ? above looks a bit more complex than a simple PN junction
http://www.allaboutcircuits.com/vol_3/chpt_2/7.html
4.
Maybe it's just me, but using the word save is confusing, why not just be clear and use the word "except"...
There is no current flow, save leakage current, in the collector circuit.
http://www.allaboutcircuits.com/vol_3/chpt_2/8.html
5.
This correspondes to 100% emitter current splitting between the base as 1% and the collector as 99%.
6.
Should this have been 0.7 V?
The heavy doping in the emitter gives the emitter-base a low approximate 7 V breakdown voltage in small signal transistors.
7.
The MOSFET described above in [the] Figure ? above is known as an enhancement mode MOSFET
http://www.allaboutcircuits.com/vol_3/chpt_2/10.html
2.
3.
4.
5.
6.
7.
