Typo
Discussion in 'Feedback and Suggestions' started by LDC3, Aug 11, 2013.
  1. LDC3
    Thread Starter Active Member
    Apr 27, 2013
    920
    160
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    When a PN junction is forward biased the current-voltage relationship is an exponential function as described by the Ebers-Moll model. This is not a breakdown condition.
    Breakdown occurs when the PN junction is reversed biased and the applied voltage reaches a point where avalanche breakdown occurs.
    The 7V breakdown voltage is correct in this case.
  3. LDC3
    Apr 27, 2013
    920
    160
    Oh, I thought it was forward bias. I see my problem. I didn't notice that it stated it was the breakdown voltage. Maybe it could be reworded to:
    The heavy doping in the emitter gives the emitter-base a low breakdown voltage of approximate 7 V for small signal transistors.
  4. MrChips
    Oct 2, 2009
    12,623
    3,451
    This is what is written:
    Your wording is slightly better.
