http://www.allaboutcircuits.com/vol_4/chpt_12/1.html
"A parallel-in/laralel-out shift register" - is it to be written parallel, not laralel?
i have entered this in the copy at ibiblio.org"Formulated" is correct.
thanks,No worries mate! A bit more:
/vol_2/chpt_13/2.html
machineid=3
A motor driven by square waves of current, as proviCed by simple hall effect sensors,
May it must be written "provided"?
Thanks,Here
/vol_2/chpt_13/6.html
It is also possible the put the rotor on the outside surrounding the stator.
Should it be TO put the rotor? Sorry, I am far from being an native English speaker, so, I don't know...
thanks for pointing out this typo.Okay, but with lower case s - "source".
Thanks,It was a quotation. The text under the last figure has to "the" in succession.
Thanks,Two "insulator"s in a row.
Appears to be a typo.
Thanks,"a approximately" must be corrected to "at approximately".
http://www.allaboutcircuits.com/vol_3/chpt_3/12.html
"If a varicap diode is part of a resonant circuit as in Figure above, the frequency my be varied with a control voltage, Vcontrol."
Is it to be may instead of my?
"Another PIN diode application is a the antenna switch here for a direction finder receiver."
Here something seems to be wrong as well.
http://www.allaboutcircuits.com/vol_3/chpt_3/13.html
"Diodes based on organic chemicals have been produce using low temperature processes."
Sorry, I am far from being an expert in E grammar, but should it be have been produced?
http://www.allaboutcircuits.com/vol_3/chpt_4/8.html
"The approximage voltage gain of the C-E amplifier in Figure belowb is -RL/REE."
Approximate? Below?
http://www.allaboutcircuits.com/vol_3/chpt_4/10.html
"This restores the AC gain since the resistor is a short for AC signals."
Isn't a capacitor a short for ac signals?
thanks Dave,I did notice a correction the other day at: http://www.allaboutcircuits.com/vol_2/chpt_6/6.html
In paragraph 2:
Spelling correction, should obviously be "circuits",
Dave
Thanks Skfir, I have corrected it at ibiblio.orghttp://www.allaboutcircuits.com/vol_3/chpt_4/15.html
" The the semiconductor die in the TO-220 and TO-247 plastic packages is mounted to a heat conductive metal slug which transfers heat from the back of the package to a metal heatsink, not shown"
Two "the"s in a row.
Thanks Skfir, I got it.the same place:
"electrically isolate the these from a grounded heatsink by an interposed mica or polymer washer. "
something seems to be wrong here.
Thanks Skfir, I have entered it.http://www.allaboutcircuits.com/vol_3/chpt_4/16.html
"This distortion distortion is unacceptable in many applications like high-fidelity audio."
the word distortion is repeated twice.
Thanks Skfir, this typo is about 7 years old. I have fixed it at ibiblio.orghttp://www.allaboutcircuits.com/vol_4/chpt_8/6.html
"We will use the form on the right" - the period is absent.
Skfir, thanks for another 7-year old error. It is entered at ibiblio.orghttp://www.allaboutcircuits.com/vol_4/chpt_8/8.html
"The solid red group is (A'+B), the dashed red group is (C'+D). "
The solid region is actually blue...
Thanks Skfir, I got it.http://www.allaboutcircuits.com/vol_4/chpt_12/1.html
I have changed it to bigger at ibibliohttp://www.allaboutcircuits.com/vol_4/chpt_12/4.html
"Note that serial-in/ serial-out shift registers come in gigger than 8-bit lengths of 18 to to 64-bits." - What does gigger mean?
