- the sentence is a bit hard to figure out.Ö" symbolizes a possible öpen" fault, while "S" symbolizes a possible ßhorted" fault.
Something seems to be generating umlauts, quotation marks, and the β symbol. O for an öpen" fault S for an ßhort" fault OK for no fault
- then I read the codes as:R1 = Brn, Grn, Red, Gld
R2 = Yel, Vio, Org, Gld
R3 = Red, Grn, Red, Gld
R4 = Wht, Blk, Red, Gld
Three color bands followed by a gold one are clearly 5% tolerance resistors. Some resistor charts are better than others. I may have seen two 6 band resistors in my life. If in doubt (real world) use an ohmmeter. The same bands on a tan phenolic body are hard to make out if painted on a dark blue body, as with some varieties of Japanese resistors.Calculate the voltage dropped by each of these resistors, given a battery voltage of 9 volts. The resistor color codes are as follows (assume 0% error on all resistor values):
