1. gorgondrak
    Nov 17, 2014
    61
    http://www.allaboutcircuits.com/vol_4/chpt_12/3.html
    When I try and go to this link it comes up blank, but there is a typo.
    DIGI book chapter 12 Shift registers part 12.3 Parallel-in, serial-out shift register. Underneath the second graphic titled "Parallel-in/ serial-out shift register showing parallel load path" it says, "...passing data to the D inputs of type D flip flops Qa Qb Dc respectively.". It should say, " ...Qa Qb Qc respectively.". The same mistake is also made at the end of that paragraph.
  2. gorgondrak
    Nov 17, 2014
    61
    In the same paragraph it also says, "...upper NAND gates..." Which I don't see depicted in the graphic.
  3. gorgondrak
    Nov 17, 2014
    61
    There is also a typo in the paragraph following the next to last graphic in part 12.3 where it calls the inputs Daa Dbb and Dcc which are labeled Da Db and Dc.
  4. gorgondrak
    Nov 17, 2014
    61
    The paragraph following the last graphic in part 12.3 says, "The data at Qb, a 0 is shifted to QC.". This needs a coma after the zero.
  5. gorgondrak
    Nov 17, 2014
    61
    Part 12.3.1 titled "Parallel-in/serial-out devices" has a typo in the second sentence which says, "For complete device data sheets follow these the links." It should say, "For complete device data sheets follow these links.".
