Hello all, this is my first time to the forum and I have a quick question.
I am trying to make an electronic switch using a very simple transistor circuit. I need to do some testing to see what my microcontrollers voltages are for bitwise 1 and 0 (i will post that later), then I will amplify it and direct that into the gate of an N type FET transistor (or at least that is my current plan). I used EveryCircuit to design this and the problem is that I dont know what common transistor characteristics are. I learned about transistors at my college this last semester and I know how to read the data sheets( to an extent), but I dont know what transistor to use or what characteristics are fairly standard for application.
so I would like to start by asking what transistors you use or recommend. How do I know what transistor to use? and how do I find the correct transistor based on the other components in my circuit.
I guess trying to figure out the serial numbers and all of their characteristics is a little scary.
thank you in advance for any help you can give me.
