thatoneguy
- Joined Feb 19, 2009
- 6,359
Any chip that can output a high is not an open collector.So based on all of your previous comments I've been able to fill in a few boxes.
Any other hints about identifying output types?
Look at source/sink ability, Open Collectors can only sink, totem pole and tri-state can source/sink, not always the same amount of current, but usually similar voltages.
Open Collector outputs, ,not in the 74xx family, are commonly used to switch the "low side"/ground connection of a higher voltage load (ULN2003).
The 7400 series with open collectors are used to "pull a bus line low" or being disconnected from it, and have relatively low current sink ability.
In general, totem pole or tri-state outnumber open collectors in most outputs.
