I am reading through an older electronics textbook I found in the library, and I am at the section regarding shunts and multiple-range ammeters. I think I understand the gist of what's going on here, except one aspect. The book says a multiple-range ammeter must use a shorting-type switch so that the meter movement is shunted even while switching ranges. The book further states that "with a nonshorting switch, the meter movement would carry all the current for the instant it takes to change ranges", which could damage the meter movement.
The book gives an example of a 100 micro-ampere meter movement with a 1000-Ohm resistance. If a nonshorting switch is currently selecting the 10 milli-ampere range, and then is switched to the 1 milli-ampere range, a nonshorting switch would momentarily cause the 100 micro-ampere meter movement to receive all the current, but wouldn't the 1000-Ohm resistance be high enough to limit any damage?
I have tried doing the math to determine something about the relationship among the 10 milli-ampere shunt, the 1 milli-ampere shunt, and the 100 micro-ampere meter movement, but I can't seem to make any sense of it.
To sum it up, I am wondering why a shorting-type switch must be used with a multiple-range ammeter, and why a nonshorting-type switch cannot be used.
Thanks!
- Jason
Thanks!
- Jason
