Type of digital circuits VHDL
Discussion in 'Programmer's Corner' started by mr_l, Sep 29, 2011.
  1. mr_l
    Aug 20, 2011
    12
    Hello!
    I need some help with following code.
    What types of digital circuits, these:
    I guess it's some type of encoder in the first case and counter in the second one. I try to find more information on the web but I can't.
    Any information or clue is welcome.
    1. architecture rtl of D2a is
    begin
    process (X0, X1, X2)
    begin
    case (X0 & X1 & X2) is
    when "100" => z <= '1';
    when "010" => z <= '1';
    when "001" => z <= '1';
    when "101" => z <= '1';
    when others => z <= '0';
    end case;
    end process;
    end D2a;
    2.entity asc is
    generic (CS : integer := 8)
    port (k, ars, srs, e, u: in std_logic;
    r: buffer std_logic_vector(Cs-1 downto 0));
    end asc;
    architecture arch of asc is
    begin
    p1: process (ars, k) begin
    if ars = ‘1’ then
    r <= (others => ‘0’);
    elsif (k’event and k=’1’) then
    if srs=’1’ then
    r <= (others) => ‘0’);
    elsif (e = ‘1’ and u = ‘1’) then
    r <= r + 1;
    elsif (e = ‘1’ and u = ‘0’) then
    r <= r - 1;
    else
    r <= r;
    end if;
    end if;
    end process;
    end arch;
  2. Maen
    Member
    Sep 16, 2011
    12
    the first one is equivalent to the following boolean equation :
    Z = X1*(X0+X2)+X0*X1*X2 (I underlined the inversion since I can't overline)
    It looks like some decoder for a display or something like this.
    Code ( (Unknown Language)):
    1.
    2. 2.entity asc is
    3.    generic (CS : integer := 8)
    4.    port (k, ars, srs, e, u: in std_logic; r: buffer std_logic_vector(Cs-1 downto 0));
    5. end asc;
    6.
    7. architecture arch of asc is
    8. begin
    9.   p1: process (ars, k) begin
    10.     if ars = ‘1’ then
    11.       r <= (others => ‘0’);
    12.     elsif (k’event and k=’1’) then
    13.       if srs=’1’ then
    14.         r <= (others) => ‘0’);
    15.       elsif (e = ‘1’ and u = ‘1’) then
    16.         r <= r + 1;
    17.       elsif (e = ‘1’ and u = ‘0’) then
    18.         r <= r - 1;
    19.       else
    20.         r <= r;
    21.       end if;
    22.     end if;
    23. end process;
    24. end arch;
    This is a up/down counter. The ports do :
    ars : asynchronous reset
    srs : sysnchronous reset
    e : count enable
    u : count up
    k : clock
    r : 8 bit output vector
    Hope this helps.
  3. mr_l
    Aug 20, 2011
    12
    Have read a bit more about digital circuits and VHDL last days.
    As I understand the code in the first case could be som type of checker
    which determines if the input values represents even or odd value.
    is this possible????
    begin
    begin
    end case;
    end process;
    end D2a;
  4. Maen
    Member
    Sep 16, 2011
    12
    No. if it would be looking for odd values it would simply check the LSB. These are 3 different signals I'd say, if it represented a value it would be quite strange to decompose the bus in three different threads instead of a 3 bit vector. If you can't provide a clearer context I don't think I can help you further. I'm also quite puzzled by the name of the process : D2a... the only thing that springs to my mind is digital to analog, but that's not it. Decimal to something maybe.
