Hello again,
Simple question.
On this forum, and on other sites, I've read that whenever possible one should tie unused IC leads to ground.
My specific question:
I'm using only 1/2 of an LM393 comparator. The diagram below shows what I've done on the left - tied all of the first comparator leads to ground - directly. But I'm not sure whether it should be directly to ground, or through a pulldown resistor (example on the right).
Which is the correct way?
My general question.
With other ICs, on those pins that I don't use, should I tie them to ground, or tie them to a pulldown resistor?
As usual, thanks very much.
Simple question.
