Tying multiple /OE together
Discussion in 'The Projects Forum' started by nethanger1, Jan 26, 2016.
  1. nethanger1
    Aug 19, 2013
    6
    Is there anything wrong with tying two active low /OE together that are being driven by the same source? I am using a MAX31856 and buffering the output using a NC7SZ125P5X. The buffer only needs to be on when the temperature sensor is enabled. This does not seem to work and I do not understand why.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Schematic please. Words fail us both in this case.
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    There should be no problem driving the chip select pin of the MAX31856 and the output enable pin of the NC7SZ125P5X with the same low signal. Do you need a pullup resistor on the enable lead of the chips?
