Correct. So can 100001 represent the value 33?negative value
noCorrect. So can 100001 represent the value 33?
Yeah, if first bit is 1 it's negative, if it is 0 it's positive. get itGood.
So now see if you have progressed enough to take a stab at the original question.
In a 6-bit two's complement representation, what is the bit pattern for the most negative value?
In a 6-bit two's complement representation, what is the bit pattern for the most positive value?
Once you have the bit patterns, then you can focus on converting them to decimal values.
"That's a mighty fine lookin' 2 there pardner!" ( Two's compliment.)If we have 6 Bit (2-komplement) and we need to find biggest and smallest number and wrote them in binar and dezcimal form. How to do it?
6 bit (Two's Complement) decimal -32, binary 111111 - that's for the biggest number
-33, binary 100001 - that's for the smallest number
Is this correct? If not can someone find my mistake.
I can'tI'm assuming you got that point. But, with that knowledge and everything else you know about two's comp (which is improving), can you figure out what the entire six-bit pattern is for the most negative and most positive values?
Here's a hint: One of the big reasons that two's comp is so popular is that, given the bit pattern for any representable value, you can get the bit pattern for the value that is one more or one less, provided it is representable, using the exact same hardware that you would use for straight (i.e., unsigned) binary.
