Two’s complement multiplier
Discussion in 'The Projects Forum' started by Rod Zero, Nov 6, 2014.
  1. Rod Zero
    Nov 6, 2014
    input A(8 bits)-> two's complement
    input B(8 bits)-> two's complement
    output F(8bits)--> F= A times B;
    How can I design an two's complement multiplier using 4bit full adder, decoder, mux, logic gates.
    The goal is to design an 8bit ALU and one of the functions that it must performs is A times B.
    So, I'm doing 1bit ALU'S and linking everything. But How can I do that?
    I saw sth about Baugh-Wooley with 4bit, but How can I design it with 8 bits?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would take the absolute value of both operands and latch the signs of the operands.
    Then I would divide each of the positive operands into two bit groups.
    For each of the four 2-bit groups in the multiplier form a 16-bit partial product from a shifted version of the multiplicand
    Add the four, 16-bit partial products
    Apply the sign from the latched sign bits of the operands.
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    The last time I checked (8 bits) * (8 bits) = (16 bits)
