two wire reversible motor 12v switch
Discussion in 'The Projects Forum' started by stealth, Aug 6, 2008.
  1. stealth
    Aug 6, 2008
    I have a two wire reversible motor for my active exhaust on my car. it was used to open and close the exhaust valve. I need help on a switch that can be reversed to open and close it. sounds simple and probly is to you, but to me just confusing :p I'm afraid I might burn something up :0
    I'm using an exhuast system from a stealth twin turbo and the engine ecu controled the motor, I can switch pollaties with the two wires and move the valve. now I just need a switch can any one help please?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    A "Double Pole-Double Throw-Center Off" (ON-OFF-ON) toggle switch wired as shown (rear view). One direction is Forward, the center is Off, and the other direction is Reverse.
    Ken
  3. blocco a spirale
    Jun 18, 2008
    1,461
    370
    What happens when the motor reaches the limits of its travel? Does it just stall?
    If the motor provides no position feedback, or means to switch itself off, then the ECU probably powered it for a few seconds and then off. Powering the motor continuously will cause it to burn-out.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Mine was a minimal answer. Maybe Stealth can provide more info...such as how the ECU that controlled the motor knew when to stop.
    Ken
  5. kammenos
    Aug 3, 2008
    127
    it is most unlikely to get a good answer without more information about limit switches or any other thing. Only 2 wires ? nothing else? No sensor?
