Good Day to you all, please i'm looking for a capacitor that has both input and output differently. what i mean, is a capacitor that can be charge through an input wire and discharge through a different output wire. thanks
That's about as close as you're going to get.¿?
Perhaps this :
Charge--------------|>|-------------(C+)------------|>|-------------Discharge
GND----------------------------------(C-)------------------------------GND
No. It's either a low inductance feed trough for one of the capacitor legs, or it's two capacitors in one case.Not thread jacking but I have a couple old ceramic cap with three legs, is that the same? ??
Assuming a common connection between the charging and discharging elements...Good Day to you all, please i'm looking for a capacitor that has both input and output differently. what i mean, is a capacitor that can be charge through an input wire and discharge through a different output wire. thanks
by Duane Benson
by Aaron Carman
by Duane Benson
by Jake Hertz
