The Tektronix 2467 has Two independent triggers for the A trigger and the B trigger , you can set A trigger to a Positive Slope and the B trigger to negative slope , the A and B trigger can have separate trigger levels and Coupling AC/DC. The A trigger can be set to Auto, the B trigger can be set to Single Sweep.
When would a Technician want to use 2 independent triggers that have a Positive slope signal on A trigger and on B trigger a negative slope?
When have you guys used the A trigger and B trigger?
In order to use the A trigger and B trigger to be independent you have to input a trigger source to an unused Oscilloscope channel
