two switches control
Discussion in 'Homework Help' started by ericyan, Sep 16, 2004.
  1. ericyan
    Sep 16, 2004
    6
    I have two particular circuits, and controled by one switch for each. But I would like to use the switch of circuit 1 to control that of circuit 2. i.e. if the switch of circuit 1 is not closed, the switch of circuit 2 is invalid to control that circuit, even pressing it.
    Can you help me to solve this problem? thank you very much.
  2. haditya
    Jan 19, 2004
    220
    can u post your schem
  3. mozikluv
    Jan 22, 2004
    1,437
    hi,
    that's what you call interlocking output of a timer. when one is working the other is not and the cycle could be broken when the other is in the process of completing its cycle.
