two switches and two relays to control motor polarity
Discussion in 'The Projects Forum' started by rynwmmr, Apr 17, 2014.
  1. rynwmmr
    Apr 15, 2014
    5
    I had made a prior post but need more clarity.
    I have two spst n.o. push button switches and two spdt relays (Bosch style). Can I get a laymens diagram draw so i know how to make the connections.
    I have a 12 volt battery, and a motor. I want to wire it so that when I press one button the motor spins one direction, when I press the other button the motor spins the opposite direction. THANK YOU
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    You can't get much more than a Layman's drawing than inwo drew for you.
    The only thing to keep in mind is that you need to keep the button pushed for the motor to run, if you need to run unattended then you would need SPST maintained switches, using the relays shown.
    Max.
  3. ScottWang
    Aug 23, 2012
    4,930
    777
    Your relays need two groups of contact, one for motor and another one for push buttons to be a self lock when the push button is released.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    Hes not changing the function of the circuit.. He just created a new thread because no one responded in his other fast enough BUT then inwo did 30 minutes after this post was created..
