Two steps forward, one step back per second?
Discussion in 'The Projects Forum' started by Obfuscator, Jul 17, 2016.
  1. Obfuscator
    Dec 9, 2010
    I need to make a 200 step/360 degree stepper motor do two increments of 6 degrees forward, one increment of 6 degrees back every second and have the sequence continue to cover 60 seconds in 1 second increments (one revolution of 360 degrees) so that each increment is 6 degrees or as close as possible for a clock which expresses two steps forward, one step back and keeps virtually perfect time. In the answer to a post a few years ago, the sequence for 3 seconds covered by a 200 step/revolution stepper which stepped exactly 18 degrees in 3 seconds is:
    second 1 = 3 x 1.8 degrees = 5.4 degrees
    second 2 =3 x 1.8 degrees = 5.4 degrees
    second 3 = 4 x 18 degrees = 7.2 degrees
    Total degrees/3 seconds = 18 degrees
    This sequence is repeated 20 x 18 degrees/3 seconds = 360 degrees/60 seconds
    I have figured that my stepper should do:
    second 1 = 7.2 + 5.4 - 5.4 = 7.2 degrees
    second 2 = 5.4 + 5.4 - 5.4 = 5.4 degrees
    second 3 = 5.4 + 7.2 - 7.2 = 5.4 degrees
    Total degrees/3 seconds = 18 degrees.
    This sequence is repeated 20 times for 60 seconds.
    Is that correct to achieve two steps forward, one step back?
  2. crutschow
    Mar 14, 2008
    13,462
    3,353
    That is a weird sequence you have, but it should do what you want.
    Obfuscator likes this.
  3. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
    I seem to remember that some stepper motors in old printers were 180 steps per revolution. Maybe Epson? That would make things easier.
  4. Obfuscator
    Dec 9, 2010
    That would be very helpful. I have a source of old multifunction printers but I need to know the model number.
