two stage common emitter amplifier
Discussion in 'General Electronics Chat' started by mrk, Jan 8, 2010.
  1. mrk
    Jan 7, 2010
    Hi , please can somebody help me to solve my assignment . the question circuit is attached and the question is ;
    1) for the curcuit design a two stage common emitter amplifier for for the following specifications ;
    RE1=REA1+REA2 , RE2=REB1+REB2 , IE1=1.8mA , IE2=4mA
    REA1=0.22RE1 , REB2=0.4RE2
    FOR BOTH STAGES ;
    β=200 , R2=0.1βRE1 , R4=0.1βRE1 , VA=100V , VE=0.1VCC , VC=0.5Vcc , VBE=0.65V
    2) PERFORM AC ANALYSIS ( from 10 Hz to 100 MHz ) and print output for V of the both stages separately .
    thanks a lot in advance for your support and so operation .
    best regards
  2. peranders
    May 21, 2007
    87
    What kind of help do you ask for?
  3. steinar96
    Apr 18, 2009
    239
    This belongs in the homework section, and keep in mind that normally people wont solve problems for you. They will however gladly help you if you show some initiative and show us what you have done so far and where you are stuck.
    So where are you stuck with this assignment ?
  4. mrk
    Jan 7, 2010
    sorry for the mistake. i have solve the circuit and find all the values , bat i dont know where i do mistake . the values taht i find is ;
    Re1= 1000ohm , Re2=450ohm , Rea1= 220ohm , Rea2=780ohm , Reb1=270ohm , Reb2=180ohm , R4=10kΩ, R2=10kΩ , Rc1=5kΩ , R1=10kΩ , Ic1=1.791mA , Vb1=1.15V , Rc2=2.2kΩ , Bb2=1.15V , R3=10kΩ
    bat my instructor is said this values incorrect . so kindly can you help me and inform me the right values .
    thanks
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hmm, for example
    VE=0.1VCC and IE1=1.8mA , IE2=4mA
    So
    Re1=1.6V/1.8mA=888=820
    Re2=1.6V/4mA=400=390
    And Rc1=6.4V/1.79mA=3.5733=3.6K
    and soon
  6. mrk
    Jan 7, 2010
    VE=0.1VCC so Ve= 0.1 X 18 = 1.8 V am i right ? why 1.6 V
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    If so I'm sorry because I assume 16V.
    So for 18V
    Re1=1.8V/1.8mA=1K; Rc1=9V/1.79mA=5K=5.1K;
    Re2=1.8V/4mA=450=470; Rc2=9V/3.98mA=2.2K.
    R2=0.1*200*1K=20K -->
    R1=( Vcc - (Vbe+Ve) )/(IR2+Ib)
    IR2=(Vbe+Ve)/R2=2.45V/20K=122.5uA
    Ib≈1.8mA/β=9uA
    R1=( 18V - (1.8V+0.65V) )/(122.5uA+9uA)=15.55V/131.5uA=118K=120K
