Why should there be any oscillations? If RFB is > 1673.424 ohms, then the negative feedback is greater than the positive feedback.The pspice shows the oscillations already for RFb=2344.06792623
For those values, the critical resistance would be 1645.1766Ω. For RFB greater than that, there shouldn't be any oscillations. I would think that if RFB > 1800Ω, there definitely shouldn't be any oscillations.Well the beta are 192, 187. This make any difference?
Sorry I haven't chimed in on this one. I've been busy lately, but I'm watching this thread with interest and would like to see your solution with the generalized admittance matrix.... I hope we'll hear from hgmjr and steveb.
Apparently a mistake has crept in there somewhere, because with the feedback resistor, the input impedance is 5506.429Ω. :-(For the first circuit with infinite feedback resistor, I get Rin=11272 ohms and for the second circuit with 2344 ohm feedback resistor, i get Rin=11180 ohms.
Hopefully, I didn't make a mistake.
I also get this value in my spreadsheet calculation.Apparently a mistake has crept in there somewhere, because with the feedback resistor, the input impedance is 5506.429Ω. :-(
Some small error must have crept in; the gain should be 689.001136. Jony130 went back and edited post #17 and got the results for the RFB = 5000Ω case.With Rfb = 5000 plugged into my EXCEL spreadsheet version ....
I get Gain= 6.9244614202E+02
That's correct.And using goal seek in the spreadsheet I get Rfb = 1.6734242404E+03
to achieve a gain of 1E+12 (not infinity but getting there!). Actually Goal Seek falls over with a target >> 1E+12 ....
All correct except for some numeric errors beginning to creep into your results around the 6th decimal place.For RFB=5K
If I don't make any mistake in calculation here are the result:
V1=0.578180V---> node 2 in your diagram
V2=-46.318011V--->it is a Ku= node_3/node_1 in your diagram
V3=-38.341042V--->Ku=node_4/node_1 in your diagram
and
Ku=node_5/node_1|=((V2-V3)/R7) *β2 *R6=689.000225[V/V]
Rin=R2/(1-V1)=18481.5798Ω ---> not take into account R1,R2 in your schematics.
And gosh I need a spreadsheet. [/URL]
Do you have any ideas on this one?You have in effect analyzed a circuit that has an AC ground connected to node 2 and and with RFB connected from node 4 to ground, rather than between nodes 2 and 4. Such a circuit has exactly the same gains from node 1 to all the other nodes.
Now, to extend the problem, imagine this. Build each circuit, my original one and the one you analyzed and enclose each one in a black box. Each circuit's reference node (ground) is connected to the metal of the box. The other 5 nodes are connected to terminals on the outside of the box. Since both circuits have exactly the same gains from node 1 to the other nodes, how can we tell them apart?
Exactly correct. Did you find the cause for the small error in gain you had in post #27?With Rfb=5000, I get Rin = 9.307408213914E+03
That's it for me - thanks for the challenge Electrician, but it's worn me out!
Thanks Electrician - I found the error in my spreadsheet and it all now agrees with the values you and Jony130 have found for the various values of Rfb.Some small error must have crept in; the gain should be 689.001136. Jony130 went back and edited post #17 and got the results for the RFB = 5000Ω case.
Interesting! It seems that the feedback modifies the effective current gains, which makes it more difficult to see the input impedance by inspection. This proves your initial point ....Apparently a mistake has crept in there somewhere, because with the feedback resistor, the input impedance is 5506.429Ω. :-(
I'll look at it some more to see if a more "intelligent" inspection can yield the correct answer, or if a full calculation is necessary.I want to show how just the addition of a single feedback resistor, RFB, between the two emitters substantially increases the difficulty of analysis.
Ah, this is interesting. I just noticed that this input impedance is what you expect if the emitter resistor of stage 1 was completely bypassed. So basically, your feedback resistor is negating the effect of the unbypassed portion of the emitter resistor on stage 1. For the AC signal, the emitter of the stage 1 transistor acts like a virtual ground. Correct?the input impedance is 5506.429Ω. :-(
Yes, I chose the value of RFB to get just that effect. Jony130 noticed it in post #13.Ah, this is interesting. I just noticed that this input impedance is what you expect if the emitter resistor of stage 1 was completely bypassed. So basically, your feedback resistor is negating the effect of the unbypassed portion of the emitter resistor on stage 1. For the AC signal, the emitter of the stage 1 transistor acts like a virtual ground. Correct?
But, which circuit have the same gains ?Now, to extend the problem, imagine this. Build each circuit, my original one and the one you analyzed and enclose each one in a black box. Each circuit's reference node (ground) is connected to the metal of the box. The other 5 nodes are connected to terminals on the outside of the box. Since both circuits have exactly the same gains from node 1 to the other nodes, how can we tell them apart?
When I said in post #18:But, which circuit have the same gains ?
For sure not those in the first post. [/URL]
I was referring to your analysis in post #13, and the second of my original circuits, the one with RFB present.You have in effect analyzed a circuit that has an AC ground connected to node 2 and and with RFB connected from node 4 to ground, rather than between nodes 2 and 4. Such a circuit has exactly the same gains from node 1 to all the other nodes.
That's very interesting. If I make RFB 2500, I get very low frequency oscillations after a second or so.
by Jake Hertz
by Duane Benson
by Duane Benson
by Duane Benson
