Two stage amplifier help (help me to learn this on my own)
gte
Joined Sep 18, 2009
357
Here is my circuit and my givens, correct me where I'm wrong.
I have decided to split the BJT and FET for now in solving some of the things.
BJT
VC - 8.04vDC Vcc - (IC*RC) = 15 - (.012*580)
VB - 2.2vDC Vcc *(R1/(R1+R2)) = 15 * (1100/7500)
VE - 1.5vDC VB - VBE = 2.2 - ~.7
IC - 12mA IC ~ IE
IB - 2mA VB/R2 = 2.2/1100
IE - 12mA VE/RE = 1.5v/125
Rin(base) - 15000 Beta * RE = 120 * 125
The BJT individual gain is Beta = IC/IB = 12mA/2mA = 6?
FET
Idss - 78.8mA (gm0 * VGSoff)/2 = (.035 * 4.5) /2
Vg - ? (is it ground?)
Vgs - -0.75v
IS - 21.4mA VS/RS = .75/35
ID - 21.4mA ID ~ IS
VD - 7.296 VD = VDD - (ID * RD) = 15 - (21.4ma * 360) = 15 - 7.704
gm - 29mS gm0(1 - Vgs/Vgs(off)) = 35mS(1 - (-.75/-4.5)) = 35mS(1-.1667) = .035 * .8333
How am I doing? Then I have to factor in Rin(total) to get the actual gain? Thanks for reading!
Audioguru
Joined Dec 20, 2007
11,248
Your circuit is not practical.
It has a low input impedance and the FET has a very high input impedance that is not wanted.
The transistor has no negative feedback so of course its output is very distorted.
Jony130
Joined Feb 17, 2009
5,487
BJT
IC - 12mA IC ~ IE
To be more precise to find Ic, Ib, Ie you need to find first Ib.
So we start with replace R1, R2 with Thévenin's theorem equivalent circuit.
Et = Vcc * R2/(R1+R2) = 15V * 1.1/7.5 = 2.2V
Rt = R1||R2 = 938Ω
So Ib = (Et - Vbe) / ( Rt + (β+1)*Re) = (2.2V - 0.7V)/ (983 +(120+1)*125) = 1.5V/16.108K = 93.121uA
So if we know Ib now we can easily find Ic and Ie.
Ic = Ib*β = 11.174mA and Ie = Ib + Ic = Ib*(β+1) = 11.267mA.
Vc = Vcc - Ic*Rc = 8.519V
Ve = Ie * Re = 1.408V
Vb = Ve + Vbe = 2.108V
FET
Vgs - -0.75v
ID - 21.4mA ID ~ IS
If we know that Vs = 0.75V then
Id = Is = 0.75V/Rs= 21.428mA
Vg = 0V and Vd = 7.285V
And gm = 29.166mS; Idss = 78m
How am I doing?
Not bad
No, you need take in to account Rin of a JFET amplifier and RL to find the total gain
gte
Joined Sep 18, 2009
357
Thank you for the response Jony
Am I missing any other values based on the problem? I'm not 100% sure how to calculate RL to get the total gain?
gte
Joined Sep 18, 2009
357
Maybe this is close?
I'm trying to figure out the RL that the FET puts onto the BJT. I know it's RC in combo with R3 (3M) and Rin of the JFET, and not RS because it has an AC filter, but I'm not sure how to calculate Rin of the JFET, as I don't have the Beta for the JFET, although I did calculate AV=gm*Rd or .0327*360 or 11.76, but I think it might be .0327 * (360 || 1000) or .0327 * 264.7 or 8.65569 gains.
I think that the gain for the BJT is Av = RC || R3(3M) || Rin of Q2 /r'e but I'm having a hard time calculating the Rin? Is it negligible because it's very high? With what I know, it'd be 1/ ( 1/580 + 1/3,000,000 + 1/RinGate ) or 579.88, it appers it makes a very little difference? So the gain would be 579.88/2.083 or 278.39 gains?
Then you multiply that times 8.6559 and you get 2409.6575391 gains? That just seems to high and doesn't seem correct?
Jony130
Joined Feb 17, 2009
5,487
Av_sf = Av1 * Av2
Av1 = ( Rc|| R3 || 1/h22 )/re
≈ Rc/re ≈ 251 [V/V]
AV2 = gm * (Rd||RL) ≈ 7.72 [V/V]
Av_sf = 1.93K [V/V]
And Rin has no effect on voltage gain as long Vin series resistance is equal 0Ω. BJT is driven from ideal voltage source.
