Two schematic component questions..
Discussion in 'The Projects Forum' started by poolman966554, Feb 18, 2014.
  1. poolman966554
    Jan 22, 2014
    29
    hey everyone, ive been looking at making this schematic, but cant seem to figure out what the value of L1 on pin 9 is.
    http://hllye.com/uploadfile/200812/18/5210216307.jpg
    Im not sure what the dotted lines indicate. Variable coil??
    Also can i leave pin 19 open? or should it short to ground?
    Thanks for your time!
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Could be a ferrite bead, those usually never have a value specified.
  3. k7elp60
    Nov 4, 2008
    478
    69
    The coil is a variable coil and is used to set the oscillator frequency. The varicap diode varies the frequency for FM modulation.
    Pin 19 can be left open.
    poolman966554 and #12 like this.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    K7 has it right.
    A few details. Hopefully including at least one thing you didn't already know.
    You could use a fuse on the power supply in case ZD1 ever becomes necessary. Theoretically, the 78L05 will protect the rest of the circuit, but no need to let it roast until you come back, possibly 3 days later.
    I think BP means, "bipolar" but now you can get capacitors that big without using electrolytic types.
    Both of the VR1's are audio taper pots.
    When it comes to 3.3 pf, basically impossible to get anything except surface mount style.
    http://www.mouser.com/Passive-Compo...SMT/_/N-bkrdv?No=25&P=1z0x6d6Z1z0x565Z1yzt48a
    The voltage regulator should be drawn like this to remind you that the capacitors need to be physically close to the regulator (to stop it from oscillating).
    poolman966554 likes this.
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    Your attached circuit shows as :
    Invalid Attachment specified. If you followed a valid link, please notify the administrator.
  6. inwo
    Nov 7, 2013
    2,435
    315
    Works for me, and I see his edit is before your post.
    Just saying.
    #12 likes this.
  7. #12
    Nov 30, 2010
    16,665
    7,310
    It works for me. Windows Vista SP2 with Firefox as a browser.
    ps, thanks for double checking it, inwo.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    It's ok now.
    #12 likes this.
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    If the 78L05 wish a 5V output then the input should be have 7.5V or some more, when the input only 5V, how many volts do you wish on the output?
  10. #12
    Nov 30, 2010
    16,665
    7,310
    There is no intent to input 5 volts. The input is labeled, "9-16V DC". That indicates that the O.P. does not want the input to be only 5 volts. For 6 volts input (a 6 volt battery), the instructions for changing components and connections are on the upper left corner in the color red.
  11. poolman966554
    Jan 22, 2014
    29
    thanks for the responses guys!
    how would i go about selecting the variable coil?
    digikey offers many in different options, especially: Q @ Freq, and inductance..
    Any ideas what values i should get?
    The way i understand it is, this is what is going to adjust the range the 4 dips witches are going to control.
    I realize its 0 to x, but i think x should be within "reason". That way the adjustment wont wont be so finiky right?
    Thanks!
  12. ScottWang
    Aug 23, 2012
    4,925
    777
    Go to check the section of coil L1 on this webpage.
