two rf sources on one antenna
Discussion in 'Wireless & RF Design' started by K-eng, May 22, 2014.
  1. K-eng
    May 22, 2014
    Hi all,
    I have a 15kW transmitter on a antenna. The duty cycle of the transmitted signal is about 20%. In between two Tx-events, I want to use another low-power source to measure impedance changes on the antenna by measuring the reflected power. The frequency is 100MHz on the high-power Tx, and 200MHz on the low-power (the antenna is tuned for both frequencies); the whole setup works with 50ohms
    I am looking for a high-power fast switching (PIN diode) network, which connects the two different transmitters and secures the low-power setup from the high-power part (circulators?)
    Since I am more a "RF utilizer" rather than "RF engineer", any suggestion is welcome. Off-the-shelf solutions preferred, but I do have a solder station ready as well.
    Thanks a lot in advance.
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    get a duplexer.
