Careful - this is a trick question.
And your answer is ??
I think it is zerohi,
What do you think it is.??
E
So what is the answer?Find Rt for this values R1 = 1000Ω and R2=0.1Ω
Also do you understand what infinity resistance means?
1kRt = 1/(1/R1 + 1/R2) = (R1*R2)/(R1 + R2) = (1000Ω * 0.1Ω)/(1000Ω + 0.1Ω) = 0.0999Ω
So for your example the answer will be ?
the 1k is like the 0.1ohm in your example so it should be 1kAre you sure ??
Yep, I just checking you.the 1k is like the 0.1ohm in your example so it should be 1k
I do not see any difference between total resistance and equivalent resistance. They are not the same?The question asks "what is the total resistance in the circuit?"
not "what is the equivalent resistance in the circuit?"
by Duane Benson
by Jake Hertz
by Jake Hertz
by Jake Hertz
